| Vista Home Premium 32bit | Rear Speakers not working Hi, just recently bought new system, screen/speakers *(x530s)/tower, etc. the whole deal. Plugged in the speakers and they are working great apart from the 2 rears arent working at all. Speakers aren't faulty (tried swapping them with the front 1s, worked fine). All plugs are checked and are plugged correctly. Went into Realtek HD Manager, set it to 5.1 but still no sound through the rears wen testing them. Read through other posts and another guy recommended setting 'environment' to 'ROOM', but nup, still no success. If this helps, under control panel/sounds/speakers (their if 3, speakers which is selected/tickd, realtek hd audio 2nd output, and realtek digital output.) as i run the tests for the rear speakers through realtek i can see the bar moving up and down. ![]() Anyone have any other suggestions or driver updates?, Ty Last edited by xvoodoo1x; 02-15-2008 at 12:06 AM.. Reason: Added more detail. |
| Vista Home Premium 32bit | Re: Rear Speakers not working problem solved, had the back speakers set as REAR not SIDE |
| ALC889A, Vista x64, Speaker Fill = rear speakers distorted | Sound & Audio | |||
| No sound from rear speakers | Vista hardware & devices | |||
| NO sound in rear speakers | Vista music pictures video | |||
| XFi Platinum Rear Speakers | Vista hardware & devices | |||
| "Full range" not working for 5.1 rear speakers | Vista hardware & devices | |||
