br>
Thread Tools | Display Modes |
#1 | ||
Newbie
![]() Join Date: Mar 2008
Vista Ultimate 64
Does anyone know of a reasonable PCI Midi card compatible with Vista 64 ? I need something to plug a Midi Keyboard and a Guitar FX processor (Midi) into. I've used the older SB Platinum i/o drive before which was useful.
Don't eat the yellow snow.
#2 | ||
Maxighb
![]() Join Date: Sep 2007
Windows Vista Ultimate 64 bit
Does it need to be a PCI Card?
Why don't you look for an USB Midi box or cable? This is cheaper, easier to use and expandable how you want for every needs. Roland has a wide range of USB Midi products avaible Roland U.S. - UM-1EX: USB MIDI Interface There are drivers for Windows Vista 64 Bit. You should know that since Steinberg started to reprogram all their professional software (Cubase,Nuendo,etc...) for Vista 64Bit support alot manufacturers are following this market...and so does Roland Music inc. If you just want to buy a midi keyboard, try to find a USB Midi keyboard. alot different avaible from M-Audio, Novation,etc.. All the Novations are for sure working on Vista 64bit (I use it everyday) ![]() |
