| Vista Ultimate X64 | Bluetooth and Audio Hi Everyone I do not know is this right discussion to post my question, if not I would like moderator to relocate my question to the right location. ![]() I have a problem with my Bluetooth Headphones and Vista. I would like to use my Nokia BH-501 (Bluetooth) as a wireless headset for Skype, MSN or any other voice programs available. Generally, I do not have problem paring headset with the computer. I can easily establish connection between computer and device but that is all. Computer under Bluetooth settings recognize device and installation is done. I use Realtek HD Audio with latest driver. Once device is paired with computer, I do not know how to make it work. If I log on MSN, Skype, etc. under sound preference my headset is not on the list so I can’t select it. Also in Realtek HD Audio Manager there is no option to add new device. I’m just wondering is there any setting apart from pairing device I need to commence to make it work? Thanks in advance Jovana |
| Vista Business 32bit | Re: Bluetooth and Audio Im having a similar problem, but with A2DP bluetooth speakers. I believe my bluetooth drivers are out of date. Can anyone help.? Laptop is an Acer Aspire 5112, with built in bluetooth |
| Vista Home Premium 32bit | Re: Bluetooth and Audio Try Bluesoleil. It is a software that will help connect all your BT devices without a glitch. I do not know if its still free but there must be older free versions. (By the way, these all work witrh vista). You can find it if u google hard enough. (Also try this link BlueSoleil, 22 million users’ choice for Bluetooth software, Bluetooth driver) Hope this helps jnraj63 |
| Vista Business 32bit | Re: Bluetooth and Audio Thanks, I will look into that. |
| Windows Vista™ Ultimate | Re: Bluetooth and Audio I just got one of Bluesoleil`s USB Bluetooth devices yesterday and Im using my headset under Vista without problems... The drivers for your device do not support using the headset as the default audio/mic, you have to download the drivers and application from the device manufacturers website or give Bluesoleil`s application a try for full functionality of the Bluetooth device. |
| bluetooth audio issues on Vista | Vista General | |||
| Line-In audio passthrough on bluetooth headphones | Sound & Audio | |||
| bluetooth headset audio not as reliable under Vista SP1 | Vista hardware & devices | |||
| Bluetooth Headset and Audio Gateway | Vista hardware & devices | |||
| Bluetooth Audio Streaming (A2DP) | Vista hardware & devices | |||
