Vista - Vista Codec Pack - 32bit & 64bit Media Player Codecs
Old 07-14-2008   #21 (permalink)
Ultimate x64 SP1
Re: Vista Codec Pack - 32bit & 64bit Media Player Codecs
Quote  Quote: Originally Posted by Jeet Chowdhury View Post
Is There Any Update Patch For 4.70 To 4.71 Cause I Will Have To Download Full File, And It Will Better If They Offer Automatic Update. That Will Be Cool....
On their website it is recommend that you UNINSTALL the previous version before installing this new one. But it's no necessary. So in term you can just install this over your previous version and your settings should stay the same. Though I can't confirm this as I follow the recommended procedure and did a fresh install.
Good Luck!
Old 07-14-2008   #22 (permalink)
Microsoft Windows Vista x64 SP1
Thanks.
Old 07-15-2008   #23 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
No, they do not offer an update.
Old 07-16-2008   #24 (permalink)
Vista Ultimate x64
thanxx for the info....i will try this ....
Old 07-17-2008   #25 (permalink)
How To Change Default Player. When Click FLV File I Need To Choose With Program Will Open It. After Choosing VistaCodec Icon Lost Why?
Old 07-17-2008   #26 (permalink)
Windows Vista™ Ultimate
Hi Jeet,
Thats a question for the developer shark007, ask him at his forum here:
Vista Codec Package - MSFN Forums
Steven
Old 07-17-2008   #27 (permalink)
Thanks Will Ask...
Old 07-25-2008   #28 (permalink)
Vista Codec Pack has Been updated with download links above...
32bit package changes include:
- add thumbnailing for several filetypes
- improve MP4 shortcuts (splitter choice)
- update ffdshow rev 2045
- update AC3filter rev 1.51a
- update Gabest's splitters/decoders rev 673
- add spdif configuration (not installed by default)
- PLS playlist recognition (not installed by default)
64bit package changes include:
- update ffdshow to rev. 2045
Old 08-14-2008   #29 (permalink)
Ultimate x64
I use Vista Ultimate x64, do I need to download and install 32bits and 64bits codec or just de 64bits?
Does this codec play mkv, avi and other formats on media player and media center?
Subtitles are ok?
Thanks.
Old 08-14-2008   #30 (permalink)
You need both the 32bit and the 64bit - install the 32bit first.
DVD player/codec pack needed Software
PLEASE HELP!!!windows media player 11 codecs Vista General
Codecs on windows media player (.MOV) Vista music pictures video
avi codec for Window Media Player on Vista Vista music pictures video
Windows Media Player, streaming and Codecs Vista music pictures video
