Vista Forums Home Join Vista Forums Webcasts Windows 7 Forum Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
How can I lower the volume more?
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 05-17-2008   #1 (permalink)
Newbie
Vista Ultimate x64
omglol741 is on a distinguished road
  omglol741 is offline
My headphones are mega loud for some reason. Right now 0 is the best volume setting lol. In XP there was a wave multiplier in the volume mixer that I used to fix that, but I don't see that in Vista. And it was annoying, because I had to change that every time I restarted. Is there a multiplier in some config file somewhere I can change to fix this permanently or something? Thanks
Old 05-19-2008   #2 (permalink)
Newbie
Vista Ultimate 32-bit
Texas
njcu is on a distinguished road
  njcu is offline
Re: How can I lower the volume more?
Right-Click your task bar
Click Properties
Click "Notification Area" tab
Checkmark "Volume"
Click "OK" button
Your volume control should present itself as an icon next to the system clock
Clicking on it will present you with the master volume control, clicking on mixer will allow you to select the volume for individual applications
If it's still too loud you could go into the control panel and go to SOUND and tweak the settings there.
If all else fails they do sell some headphone with volume control built in and you can control it that way
Display Modes
lower score PaulM Vista General 9 09-21-2007 07:19 PM
Re: FPS much lower in vista than in xp... Bob Croost Vista Games 0 10-03-2006 04:11 PM
Re: FPS much lower in vista than in xp... Bob Croost Vista Games 0 10-03-2006 04:07 PM
Re: FPS much lower in vista than in xp... Glenn Edler Vista Games 0 09-07-2006 11:32 AM
How do you intentionally LOWER the framerate? Lorin Thwaits Avalon 4 07-13-2006 03:22 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
