Vista Tutorial - Can't record anything
Old 05-23-2008   #1 (permalink)
Newbie
Vista Business 32-bit
Hi!
The problem is in the title. My computer will not record anything. Not from a cassette deck, neither from a microphone. There were two things I did before even trying to record anything, perhaps it screwed something up.
1. I installed VLC media player (to be able to watch video DVDs - other progrms refused to do it on this computer. It was a drag.)
2. I installed Sound Forge 7.0. A mistake I guess, seems it's not compatible. I uninstalled the program, but it didn't help.
Otherwise the sound works, the mic also - with Winamp shoutcast for example. But it won't record. It might be that it would, but for some reason the recording sound level is frozen at close to 0 level and it won't budge - in Sound Recorder that is, a program that came preinstalled. In the shop they've tried to help, but to no avail, and if I got it right they could not change the recording sound level for Windows Movie Maker, which they used to test the problem. The recording level in the sound options in control panel is on max, but it doesn't help. What to do?
Oh yes, and it just stopped voice info om avast updates. Just some days ago. But maybe that's not related.
I'm no computer wizzard, so if someone could help in a simple English...
Old 05-23-2008   #2 (permalink)
ɠɛɐǨ
Windows Vista™ Ultimate
Re: Can't record anything
Hi ewa,
checkout these topics for some more info if it helps...
Vista Codec Pack - 32bit & 64bit Media Player Codecs
I will get back to you with the other link when our website upgrade is completed, it has information on sound issues you might find useful.
Steven
Re-record over a CD -R or DVD-R Vista music pictures video
Can't record stereo mix, and it isn't disabled... can't record line either? Vista General
record Vista music pictures video
