| Vista Ultimate x64 | Dolby Control Center Vista x64 DL Hi Guys, ive got a Intel DP35DPM mainboard, and the Sigmatel Audio device works in conjunction with Dolby Control Center. however it seems to only work on Vista x86 not x64. ive managed to locate the stapi32.dll file and place it in system32 but even though i can install it, and the tray icon loads, the program fails to show the control panel. i know full well there is only mention of this program on Vista 32bit, but im hoping i can get help making it work on x64 ultimate, or get news on when the x64 version is available? |
| ultimate x64 | Re: Dolby Control Center Vista x64 DL Yeah, I have exactly the same problem and same mainboard. I'm hoping that the big guys like Intel will trick out their software so we can actually take advantage of having 64 bit hardware. and sooner, rather than later |
| Vista X64 Ultimate | Re: Dolby Control Center Vista x64 DL Easy go to the webpage here and in the drivers section, the first driver listed is the latest unified driver containing 32bit&64bit XP, as well as 32bit&64bit Vista software for the onboard sound. The driver also has the IDT app with Dolby Surround on it. Download Search Results The latest sound driver was released on May 22ND. |
| ultimate x64 | Re: Dolby Control Center Vista x64 DL Well thanks for that, but I just updated the driver, and downloaded the dolby program today, with the same result. But I'll go check again and see if i got the wrong stuff, but i followed all the right links for the DP35dp board. just an update, i did use the 5-22 version. Last edited by gmorgjr; 06-08-2008 at 03:05 PM.. Reason: UPdate and correct spelling error |
| Dolby Control Center | Sound & Audio | |||
| Dolby Digital 5.1 Issue Under Vista Ultimate 32bit | Sound & Audio | |||
| Dolby Digital Live and Vista x64? | Sound & Audio | |||
| Windows Vista to Output to Dolby Digital? | Vista General | |||
| ASUS WLAN Control Center for Vista 32 - bit ????? | Vista networking & sharing | |||
