| Vista Home Premium 32bit. | Sound keeps crashing. Ok I had a problem this morning where the sound icon on the bar had a red X on it and said no sound output is installed. I had this problem once before and re booted which I did this time and It worked. Sort of. I have now a problem that I cannot change the volume of my sound. I can't open the volume controler via double clicking the icon and when I try to access the sound levels via the control pannle Windows explorer crashed ans says 'Windows Shell Common DLL is not responding'. I don't understand the problem. Is it a corrupt file of a virus causing it? |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Sound keeps crashing. It might be - or it might be a simple file corruption due to hardware failure - or it might be file corruption due to a software failure. See System Files - SFC Command to get an idea of what you should do to check your system. |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| vista update crashing c media sound | Sound & Audio | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
