Can someone post the regedit for enabling mic boost for vista ultimate x64? I had it before but then reformatted and lost the directions. Please help and thank you very much.
This is actually easier to do through audio properties. I don't know what audio you have on your system, but the following step by step instructions are for mine and should be easy to adapt for yours. If you want specific instructions, please supply more details of your system.
Dwarf
1) Right-click the speaker icon in the system tray.
2) Select 'Recording Devices'.
3) Highlight 'Microphone'.
4) Click 'Properties'.
5) Select the 'Custom' tab.
6) 'Mic Boost' is on this page. Enable or disable it as required.
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
Thanks for the reply but there is a problem with it. My custom tab does not have the mic boost option. I was actually able to go into the registry and searched for MicBoost and found the reg I needed. It was default set to 0 so I flipped it over to 1 and now everyone can hear me clearly. The location of the MicBoost regedit is:
Scroll down on the right hand side and look for MicBoost. Double-click it and put a 1 where there was a 0. Now you have MicBoost and everyone is happy.
Logitech G15 (gen 2)
Logitech MX Master (shared)
Operating System
Lenovo ThinkPad E545
AMD A6-5350M APU
Lenovo
Radeon HD (Embedded)
Conextant 20671 SmartAudio HD
Lenovo 15" Matte
1680 * 1050
did you try just doing a search in the regedit? Open regedit and hit ctrl-F and type in "MicBoost" one word. That brought it up for me so hopefully it will work for you to. Good luck.
Operating System
AMD A6-5350M APU
Lenovo
Lenovo 15" Matte
1680 * 1050
