| Vista Ultimate x64 | Mic Boost Can someone post the regedit for enabling mic boost for vista ultimate x64? I had it before but then reformatted and lost the directions. Please help and thank you very much. |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: Mic Boost Hi Cakewalker and welcome to the forums ![]() This is actually easier to do through audio properties. I don't know what audio you have on your system, but the following step by step instructions are for mine and should be easy to adapt for yours. If you want specific instructions, please supply more details of your system. Dwarf 1) Right-click the speaker icon in the system tray. 2) Select 'Recording Devices'. 3) Highlight 'Microphone'. 4) Click 'Properties'. 5) Select the 'Custom' tab. 6) 'Mic Boost' is on this page. Enable or disable it as required. |
| Vista Ultimate x64 | Re: Mic Boost Thanks for the reply but there is a problem with it. My custom tab does not have the mic boost option. I was actually able to go into the registry and searched for MicBoost and found the reg I needed. It was default set to 0 so I flipped it over to 1 and now everyone can hear me clearly. The location of the MicBoost regedit is: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E963-E325-11CE-BFC1-08002BE10318}\0000\Settings Scroll down on the right hand side and look for MicBoost. Double-click it and put a 1 where there was a 0. Now you have MicBoost and everyone is happy. |
| Vista Ultimate 32/Windows 7 Dual Boot | Re: Mic Boost Nice find. Ill have to remember that one! |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Mic Boost I can only go as far as Code: HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E963-E325-11CE-BFC1-08002BE10318}\
| | #6 (permalink) |
| Vista Ultimate x64 | Re: Mic Boost did you try just doing a search in the regedit? Open regedit and hit ctrl-F and type in "MicBoost" one word. That brought it up for me so hopefully it will work for you to. Good luck. |
| | #7 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Mic Boost I used RegScanner Tool: Alternative to RegEdit find/search of Windows - the 64bit version and ran it administrator and it did not find any reference to it at all. Then again my mic is not connected right now (have a USB headset for notebooks). perhaps that is why I do not see it.... |
| Mic Boost | Sound & Audio | |||
| no mic boost? | General Discussion | |||
| Mic boost | Vista hardware & devices | |||
| ready boost | Vista General | |||
| Does Ready Boost use a lot of CPU? | Vista performance & maintenance | |||
