| Vista Home Premium 32bit | itunes, can't burn cd Hi all, have just got into itunes and can't burn cd. I get message that reads "Can not burn cd. An unknown error has occured." Can burn music with Media Player using my own library with no problems. |
| Vista Ultimate 32/64 bit | Re: itunes, can't burn cd Seems there alot of people who have this same problem, mostly with Dell. iTunes Error 2131 I don't use iTunes for burning. I would suggest either Imgburn or Burrrn! |
| Vista Home Premium 32bit | Re: itunes, can't burn cd Thanks for the info, seems I am a bit stuck now as I have no idea how to burn using Imgburn or Burrn!, this computer stuff is pretty new to me, once things get compicated I am stuffed....thanks again, cheers Bob. |
| Vista Ultimate 32/64 bit | Re: itunes, can't burn cd Burrrn! is pretty easy, but then again so is Imgburn while it is much more advanced. To burn with Imgburn see this guide ~ How to burn an Audio CD from music files using ImgBurn - ImgBurn Support Forum To burn with Burrrn! I think you can just drag and drop your files into the queue... http://www.burrrn.net/?page_id=4 ...it's been a while since I've used it since Imgburn took up audio support. Both programs are free, but Imgburn is a full featured burn engine which can also burn image files and video files as well as data. |
| Vista Home Premium 32bit | Re: itunes, can't burn cd Thank you so much for your help...I really appreciate it. Will get onto it, hopefully without blowing myself out of the water... Thanks again, Bob. |
| | #6 (permalink) |
| Vista Ultimate 32/64 bit | Re: itunes, can't burn cd No problem Bob and good luck. Let us know if you hit any bumps in the road. |
| 'Burn Failure' trying to burn a video DVD inside Vista Media Cente | Vista music pictures video | |||
| Can't Burn CD's in Itunes | Vista music pictures video | |||
| When I download itunes I'm unable to burn any CDs | Vista music pictures video | |||
| once iTunes looses the input focus, the CDROM device disappears inthe iTunes application | Vista General | |||
| Itunes wont Burn Cd | Vista music pictures video | |||
