Vista - Error message on restart
Old 07-19-2008   #1 (permalink)
Vista Home Premium 32bit
New motherboard installed by technician (it was under warranty). Every time I restart now, I get error message:
"HP MS display has stopped working" click check online for a solution which I do and nothing happens. Everything seems to be working fine except I get this error message every time.
Problem signature:
Problem Event Name: APPCRASH
Application Name: dthtml.exe, etc.
How can I get the error message to stop? Thanks.
Old 07-19-2008   #2 (permalink)
Vista Ultimate 32/64 bit
Re: Error message on restart
Do you have a Gateway or Samsung monitor? Most hits I see on Google are that this program is tied to Gateway and Samsung display and monitors changes in the optimal settings on your display. It could be tied to other monitors and may not be necessary to have on your PC. You could try reinstalling it to see if it rectifies your problem...I'm not sure it is actually needed at all though as it doesn't appear vital to the operation of you display
Detail of MagicTune(DTHtml.exe) - Startup Application Knowledge Base for Windows
Old 07-19-2008   #3 (permalink)
Have a brand new HPw1907 monitor that we got just before the new motherboard. Monitor works fine; just don't want this error message forever.
Old 07-19-2008   #4 (permalink)
If your new HP monitor came with software I would reinstall try to reinstall it to see if it rectifies the error.
Old 07-19-2008   #5 (permalink)
Ultimate x64
Either delete magictune or disable in start up. You dont need it you can change monitor settings in control panel. Or if you like it, see if they have update on software.
Error Message on Restart Vista General
i cant send a message with out restart pc. Vista mail
restart message. Vista General
restart message Vista General
