Vista - No "Windows" sound in Vista Business 32 SP1
Old 08-15-2008   #11 (permalink)
Vista Business SP1 32bit
Re: No "Windows" sound in Vista Business 32 SP1
Quote  Quote: Originally Posted by motarola2 View Post
try a start up repair. that has fixed some odd issues for me, one of them was no sound.
Hi motarola2, thank for the info. My Vista DVD is the first isse, no SP1. My Vista instalation is SP1, upgraded from the Web.
Can I do the repair process in this scenario?
Old 08-15-2008   #12 (permalink)
Vista Ultimate SP2/Windows 7 Ultimate x64
Old 08-15-2008   #13 (permalink)
Thanks Ex_Brit, I´ll generate my Vista SP1 boot DVD and use it in the repair process.
Old 08-15-2008   #14 (permalink)
You're welcome. That's what I did.
Old 08-15-2008   #15 (permalink)
Windows Vista™ Ultimate
Hi lcdsantos,
If you can hear sound that means the drivers are correctly installed and working, so thats not the problem...I guess you may have forgot to set the correct 'default' device for sound to use the correct output for other applications
Control Panel\ Sound\ Playback-Tab
Right-Click the Audio Device and click 'Set As Default'
Sometimes Windows will automatically set the device as 'Digital Output' and require you to set 'Speakers' as the default device, It might also help to use the 'test' option located there to determine the correct output device and then set that one as 'default'
Steven
Old 08-15-2008   #16 (permalink)
Vista 64-bit Ultimate Win7 64-bit Ultimate XP SP3 32-bit Pro
Hello all.
Brink has created this excellent, all inclusive SP1 slipstream tutorial here at Vista forums.
Please, feel free to have a look at it.
Vista SP1 Slipstream Installation DVD
Later Ted
Old 08-15-2008   #17 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Quote  Quote: Originally Posted by lcdsantos View Post
I have a PC with a Gigabyte GA-P35C-DS3R (rev. 1.x) mobo (GIGABYTE - Product - Motherboard - Overview - GA-P35C-DS3R (rev. 1.x)). It comes with a on board Realtek ALC889A sound chipset. I have installed the latest sound driver from Gigabyte (GIGABYTE - Support - Motherboard - Driver - GA-P35C-DS3R (rev. 1.x)) but I have a weird case... The Windows events sounds are not working... When Vista starts, when I increase the sound using slide sound systray control, when some clip plays on a youTube clip... No sound! But when I use, for example aimp2 music player, or when I do the realtek audio manager sound test... I got the sound!!! I´m not sure, but I think the problem started after the SP1 upgrade. Best regards, Luis Santos
Quote  Quote: Originally Posted by dmex View Post
Hi lcdsantos,
Steven
Hmmm - that would make sense but it still concerns me that AIMP will play music.....
Old 08-16-2008   #18 (permalink)
Hi lcdsantos,
Steven
Hi Steven, thanks for trying help. I have already double checked this and the default playback is already correctly setted to the analog output.
Look the dialog. It´s in brazilian portuguese, but you can easy confirm this by the icons... "Auto-falantes" means loudspeakers in portuguese.
It I right-click on auto-fal... err... loudspeakers and test them, the sound works! Look the second picture, where you can see the "vu meter" sound feedback:
Icons and GUI are really a little great invention. Thanks parc.
Old 08-16-2008   #19 (permalink)
Gods, I am an idiot...
Santos - if you click *once* on the sound icon in the system notification area, you get a popup with has the volume level and the word mixer underneath - if you click on mixer, you get the Sound mixer - check to see if Windows Sounds are muted or not...
Muted:
Name:  Mixer Windows Sounds disabled.PNG
Not muted:
Name:  Mixer Windows Souneds enabled.PNG
Old 08-16-2008   #20 (permalink)
John you're a genius, I'd forgotten all about that mixer. I'm hoping that's the answer.
upgrading from "Vista Home Premium" to "Vista Business" or "Vista Ultimate" Vista account administration
Have Vista Home Premium - is "Business" or "Ultimate" better? Vista General
WM5 Sync with Vista "Windows Calender", "Contacts", and "Mail" Vista General
"Windows Media Center" upgrade to "Vista Business" ? Vista installation & setup
Q&A: "Business Value" Launch of Windows Vista, 2007 Office System and Exchange Server 2007 Creates Groundbreaking Opportunities for Partners Vista News
