| Vista Ultimate x64 SP1 | Trouble using my 7.1 speakers Hi, I just bought my new Creative T7900 speakers which is 7.1. I have DP35DP Media series board with a built-in 7.1 sound card that has a driver from SigmaTel (default). The problem is I can't use my 7.1 speakers. The only speakers working are the two front speakers and the subwoofer when I play Windows Media Player 11 and Windows Media Classic Player, but when I ran a test on the config settings of SigmaTel, this time 5.1 speakers worked (excluding the side pair speakers). That I discovered, the audio cable that was included in the T7900 package is for 5.1 speakers only. One end of the cable has 3 pins and the other end has 4 pins which is standard for 7.1 speakers (Black for rear speakers; Lime-green for front speakers; Grey for side speakers; Orange for center speaker/subwoofer). But when I checked the quick installation manual, the cable included with the package is correct (3-pins : 4-pins). I only want simple thing to happen. I want my T7900 work on my PC that has built-in 7.1 sound card. Can someone help me about my audio problem. Thanks a lot. |
| Vista Ultimate x64 SP1 | Re: Trouble using my 7.1 speakers Help me please! |
| Vista Home Premium x64 | Re: Trouble using my 7.1 speakers What is it you're playing? Sounds to me almost like you're just playing a stereo file. The source has to be encoded for 5.1 or 7.1 to actually play all channels, otherwise you'll just hear stereo. i.e. if you're just playing a CD, or MP3 or AAC of a CD all you'll get are the front two speakers and sub. You said the test allowed you to hear the surround speakers, that should mean all is well. |
| Vista Ultimate x64 SP1 | Re: Trouble using my 7.1 speakers What is it you're playing? Sounds to me almost like you're just playing a stereo file. The source has to be encoded for 5.1 or 7.1 to actually play all channels, otherwise you'll just hear stereo. i.e. if you're just playing a CD, or MP3 or AAC of a CD all you'll get are the front two speakers and sub. You said the test allowed you to hear the surround speakers, that should mean all is well. |
| Vista Home Premium x64 | Re: Trouble using my 7.1 speakers As far as movies, are you hearing dialog through the center channel speaker? For a good surround test there are movies that are better than others. The Lion King is a particularly good surround movie, so is Contact, Saving Private Ryan, or any of the LOTR movies. Click here , this will take you to a page where you can download a sample 5.1 file and play in windows media player. Try it and let me know what happens. |
| Using External Speakers and Laptop Speakers | Sound & Audio | |||
| external speakers not working/pc has internal speakers | Sound & Audio | |||
| Speakers sound to "0", but there is still sounds from speakers | Vista music pictures video | |||
| Re: new speakers | Vista installation & setup | |||
| USB speakers wiped out my built in speakers | Vista hardware & devices | |||
