Vista - Realtek High Def back panel greyed out vista x64
Old 08-29-2008   #1 (permalink)
vista x64
The back panel jacks are greyed out in my realtek audio manager. I have the front panel jack detection disabled, otherwise all of the jacks are greyed out and I don't get any sound at all. I have speakers connected to the green line out of both the front and back panel, and both produce sound after a system boot up, but sometimes the back panel stops producing output, although the front panel continues to function. I didn't have this issue in xp at all, just vista. Anyone know a fix?
Old 08-29-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: Realtek High Def back panel greyed out vista x64
Hi, damnchow, and welcome to the forums.
A lot of people seem to be having issues with RealTek HD audio, either the back panel or the front panel, but I have been one of the lucky ones in that I don't have any such issues. Part of that may be because I don't use the front panel at all, and only use the back panel, so nothing ever gets changed.
At any rate, there are at least three threads I know of off the top of my head in this forum about issues which, if not identical, are very similar to your own. Unfortunately, none, AFAIK, have gotten any resolution.
Realtek High Definition Audio Problem Vista hardware & devices
back panel not working for latest realtek driver! Sound & Audio
New Realtek High Definition Codec Released Yesterday (Ver. 1.67) Vista General
REALTEK High Definition Audio 1.48 (beta) for Vista x86/x64 Vista hardware & devices
REALTEK HIGH DEFINITION AUDIO FOR HP M7160N Vista General
