| XPS | How do I change audio drivers? I have recently had a windows vista laptop with a sigmatel high definition audio codec. However this codec/driver cannot record audio direct from my sound card, it can only record through noise through the speakers. So I decided to obtain and install the realtek audio driver which I used on my previous windows xp as this can record directly from the computer sound. However I don't know where to put any of the filesso I can select it as default instead of sigmatel. Can anyone help me? |
| M-Audio Firewire Audio Drivers | Vista hardware & devices | |||
| How do I change audio settings??? | Vista hardware & devices | |||
| Audio drivers for Intel Sigmatel onboard audio | Vista hardware & devices | |||
| If you have a HP Laptop and No Audio Drivers/Audio Problems | Vista hardware & devices | |||
| Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur | Vista hardware & devices | |||
