Vista Tutorial - sound and video skip vista 64
Old 09-05-2008   #1 (permalink)
Newbie
Vista home premium x64
i just noticed that when my sound skips so does my video
are there any fixes for this?
does this with both sound cards built in and blaster se
thanks
Old 09-05-2008   #2 (permalink)
Microsoft® Windows Vista™ Home Premium
Re: sound and video skip vista 64
How long have you had this problem?
Old 09-05-2008   #3 (permalink)
Newbie
about 3 weeks just got this computer
Old 09-05-2008   #4 (permalink)
Yay Minnesotan, but anyways, I've read some negative reviews (and a lot of positive ones) about the sound card you have boughten (One stated that if you have a problem with it it may be the way you installed the card). What kind of graphics/sound card are already built into your computer?
Also humor me and take a look at your updates which can be found in (control panel/system and maintance/windows update) and then click on view update history, and see if anything matches up with the time period the problem started.
If you could provide more system specs. that would be helpful.
Take a look at this website, and see if this gets you headed in the right direction
Windows Vista Help: Tips for fixing common sound problems
Vista chkdsk wont skip Vista performance & maintenance
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Vista video streaming has pauses in video and sound Vista music pictures video
Vista Media - TV + DVD video but no sound. Vista General
Vista Media Center no video, only sound. Vista music pictures video
