| 09-07-2008 | #1 (permalink) |
| | No sound in Bioshock Hi, I use vista ultimate x86 and almost everything works fine. Unfortunately the sound stops working in Bioshock. The game works perfect on XP. I have REALTEK sound card with drivers from MSI (Motherboard). Other games works ok. Did anybody have the same issue? I'd appreciate any help. Regards |
| My System Specs |
| 09-09-2008 | #2 (permalink) |
| | Re: No sound in Bioshock Hey there, first things first. 1. Have you installed the latest patch for the game ? 2. Have you installed the latest patch for your soundcard ? 3. Have you checkt he features/options ingame for the sounds ? |
| My System Specs |
| 09-09-2008 | #3 (permalink) |
| | Re: No sound in Bioshock thanks, but already fixed the problem. just needed to reinstal audio driver and download updates for vista. regards |
| My System Specs |
| 03-29-2010 | #4 (permalink) |
| | Re: No sound in Bioshock i found a fix that fixes all bioshocks problems and i posted it in my youtube vid YouTube - bioshock 1 FIX |
| My System Specs |
| Similar topics to: No sound in Bioshock | ||||
| Bioshock Sound | Gaming | |||
| Bioshock | Vista Games | |||
| BioShock sound on Vista | Vista Games | |||
| Bioshock help! | Vista Games | |||
