Hey all,
Have a little problem, that while not the end of the world, though I would post about and see if maybe there is a solution out there I might not know about.
As other posts of mine mentioned, I recently made the Move not only to Vista, but x64 as well. Things have been overall fine, but something did catch my attention recently.
I've got an X-Fi Fatality Card and a front Drive Bay (actually from the Audigy ZS2 if that makes any difference at all) I started noticing last night when I am in windows, with the speakers on, but not doing anyhting, there is a constant amount of low level noise. Kind of like the sound you hear when you have speakers not playing anything turned up too loud. I can in fact turn mine up to amplify this sound. Before Vista, my speakers were dead silent even at full volume unless they were actually playing something.
Oh my speakers are Logitech Z-5500's hooked up via the 3 cable direction connection.
I get sound in everything fine. It's just this non noise I'd like to get rid of. All drivers and what not are current as far as I know.
