| Vista Home Premium 32bit SP2 | Missing "ping" when i alter the volume I know this is an almost trivial thing but the little details are what make something work smoothly i think so this problem is bugging the hell out of me. When i change the volume on my computer by using the slider, accessed by the little speaker symbol at the bottom right of the windows taskbar, it always made a sound whenever i changed the volume. Now, for some reason, there is no "ping" like sound when ichange it. Why is this and how do i fix it? Thanks. |
| Vista Ultimate 64bit SP2/ | Re: Missing "ping" when i alter the volume Do you still have other sounds other than the ping. |
| Vista Home Premium 32bit SP2 | Re: Missing "ping" when i alter the volume |
| Windows 7 RC x64 (7100) | Re: Missing "ping" when i alter the volume Great! So, what did you do to solve the problem? In case somebody else has the same missing-sounds issue. |
| Vista Home Premium 32bit SP2 | Re: Missing "ping" when i alter the volume The other day i was messing with a microphone and must have done something with the default windows sounds. When i checked, the sounds were all off (the properties were set to "no sounds"). Don't know exactly how it got like that because i didn't directly do it myself But i just had to set it back to "Default Windows" sounds and it solved the problem. Didn't think of it sooner because i hadn't done anything that should have knocked it off. |
| "cannot open volume for direct access" - error message re chkdsk | Vista performance & maintenance | |||
| Exception calling "Send" with "1" argument(s) error using PING | PowerShell | |||
| Chkdsk fails with error message re no "direct access" to volume | Vista performance & maintenance | |||
| Missing "Documents" and "Music" folder. | Vista General | |||
| Missing "Documents" and "Music" folders after upgrade from Windows XP. Anyone know how to recreate them? | Vista installation & setup | |||
