Vista - sound trouble
Old 09-28-2008   #1 (permalink)
Vista Home Premium 32bit
sound trouble
in the last 20 seconds of every song i have sound trouble-it goes all crackly and jumps a few seconds.
any advice?
Old 10-03-2008   #2 (permalink)
vista home premium SP1 32bit
Re: sound trouble
are you playing music from a CD/Hard Drive?
if its a CD that you copied yourself, try using another CD as it may have been distorted as it was writen to the disc.
if you bought it from a shop, try playing it in another CD player. if you dont have another CD player, try it in a DVD player, most have the capabilities to play such files.
are you playing it through windows media player??
USB Sound Card Trouble Sound & Audio
Sound card trouble on Vista x64 Sound & Audio
Solved No sound when playing music or video, but internet sound works fine Sound & Audio
Trouble with Sound Please Help Vista hardware & devices
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
