Vista - Audio from DVDs won't play, video does.
Old 09-29-2008   #1 (permalink)
Vista Home Premium 32bit SP2
As of about a week ago, my pc has stopped playing the audio from DVDs only. It plays all other audio and video (even the DVD's video) but not the DVD audio.
I've re-installed my sound card drivers and i've got the codecs and it still won't work.
Recently, i started messing with a new microphone and the sound settings in control panel so i assume it's something that's happened around then but i cant find anything that seems to be wrong.
Anyone got any ideas?
Old 09-29-2008   #2 (permalink)
Vista Ultimate x64
Re: Audio from DVDs won't play, video does.
may be ur DVDs not correct.. try to use other DVD audio
Old 09-29-2008   #3 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
This tutorial may be useful - you may want to check under the tabs
Audio Device - Enable Hidden Devices
you might also try a system restore to a point where it was working
System Restore - How to
SIW2
can't play any video or audio Vista music pictures video
MovieMaker doesn't play imported video - only audio Vista music pictures video
Cmrcl Video DVDs Won't Play in USB Device Vista music pictures video
Unable To Play Audio/Video Files Vista music pictures video
Why does mpeg video play for 1 second while audio plays fine? Vista music pictures video
