Vista - Driver conflict problem
Old 10-02-2008   #1 (permalink)
vista 64
Hi guys,
I'm having following problem:
1. I'm having PCI slot Realtek 8139/810x Ethernet card and Creative Sound Blaster Audigy 2.
Network card is working just fine. I can switch PCI slots and the realtek network PCI card is working fine.
2. I insert in the secound PCI slot Creative Audigy 2 Sound card.
after reboot i'm able to install creative drivers. Creative card works fine, BUT MY ETHERNET CARD IS NOT RECOGNIZED ANYMORE. It goes in Other Hardware as :
PCI Input Output device . It cannot find any driver. I give in device manager Update Driver. and then the directory of RealTek driver. It doesn't work.
Even if i install manually the realtek driver it still does not work.
After ejecting the Sound Blaster card from the PCI slot the NETWORK CARD works just fine.....
What can be the reason for this problem ?
Old 10-02-2008   #2 (permalink)
vista home premium SP1 32bit
Re: Driver conflict problem
do you still get the problem if you change them around, so both cards are in a different slot to the one they were installed in??????? (both at the same time)
network problem; ip address conflict Virtual PC
Network 'Identifying' Difficulty with Bluetooth MS Driver(s)--Conflict? Vista 64-bit Ultimate Vista networking & sharing
Blue Screen Crash Dump - Driver Conflict Vista hardware & devices
USB and vista sound driver conflict Sound & Audio
NVidia raid driver update conflict. Vista General
