| Windows Vista Home Premium. | No sound after an update. So I just updated Vista on my machine, and after it finished updating, and restarting, my sound was gone. And every time I try to turn up the volume it says "No Audio Output Device Is Installed". But it was working before the update. D= HELP. PC: HP Pavilion dv 6000 (GM006UA#ABL) Other bits of information I also don't understand can be found here. I have no idea what that means, but it might be handy information. |
| vista home premium SP1 32bit | Re: No sound after an update. can i start by asking, did you use windows update also, did you install vista SP1 (Service pack 1) just before this problem occured if you used windows update, open it and click "view installed updates" (top left of the windows update window) reply to this message and list with all the updates you installed on the same day your problem started to occurr and me/another member will do some digging to see what might have caused the problem... untill we know this information we won't be able to help you further. i will keep an eye out for your reply........ |
| Vista Ultimate 64bit SP2/ | Re: No sound after an update. This problem was all ready solved. |
| Vista 32bit SP1 | Re: No sound after an update. Uninstall the drivers & then download & install the latest from the manufacturers website. |
| Windows 7 RTM 64-bit | Re: No sound after an update. perform a system restore and the sound will be back. |
| | #6 (permalink) |
| Vista Ultimate 64bit SP2/ | Re: No sound after an update. Parziale already has the problem fixed by downloading the drivers and installing them from the other thread post. |
| | #7 (permalink) |
| windows vista home premium 32bit | Re: No sound after an update. hey, i have the same problem as well i also updated it n after the sound was gone noting "no audio output device is installed" but mine is HP Pavilion dv2000 (GA726EA#ABV) what shall i do!! :S |
| | #8 (permalink) |
| Vista Ultimate 64bit SP2/ | Re: No sound after an update. Goto HP's website and download the audio drivers here is the link omom. Conexant High-Definition Audio Driver* |
| | #9 (permalink) |
| Vista Home Premium 32bit | Re: No sound after an update. This happened to me after upgrading from Home Basic to Home Premium. I could get no sound for some time then some clever guy in the shop where I purchased my computrer upgraded my sound drivers from "SigmaTel Audio CODEC" to "SigmaTel High Definition Audio CODEC", obtaining some drivers from the internet somewhere, and it has since all worked fine since. Rgds Nick the New |
| no sound after update vista sp1 | Vista General | |||
| If you have a Toshiba P105 S6177 and have no sound after update tr | Vista hardware & devices | |||
| After Windows Update I Have No Sound | Vista hardware & devices | |||
| Help! No sound and unable to update driver since SP1 | Sound & Audio | |||
| Sigma Tel update kills sound | Vista General | |||
