| | Vista - Realtek Vista_R205.zip/exe???? |
| 10-03-2008 | #1 |
| Vista Ultimate | Realtek Vista_R205.zip/exe???? Hi, I have been downloading and installing Realtek Drivers, on different PCs' for years, but for some reason I cannot get Vista_R205, to install. I have been trying everything I know for the past 2 days, but no matter what I do, it installs upto the same point everytime then fails???? I have downloaded this particular version six times already (both .zip and .exe, all to no avail. Have also searched the internet for any other similar problems but can find nothing, so I don't think its a general problem!! Would be most grateful for any constructive advise. Kind regards, Algypalgy. |
| 10-03-2008 | #2 |
| Vista Ultimate 64bit SP2/ | Re: Realtek Vista_R205.zip/exe???? Are you getting any errors or does it just stop. |
| 10-04-2008 | #3 |
| Vista Ultimate | Re: Realtek Vista_R205.zip/exe???? Thanks mansrm81 for your reply, answer is yes, but all it says is "driver stopped" Regards, Algypalgy. |
| 10-04-2008 | #4 |
| vista 64-bit ulimate sp1 | Re: Realtek Vista_R205.zip/exe???? did you try d/l from diff sites the reason i state this: the last few days i had the same problem went to the site early in the morning and d/l with no problem worked for me hope that may work for you |
| 10-05-2008 | #5 |
| Vista Ultimate | Re: Realtek Vista_R205.zip/exe???? Thanks for that njnitehawk, yeah tried all that, even waited for over an hour to downlaod from Realtek's own site. I will keep trying, even if I have to wait for a new version. Kind regards, Algypalgy. PS. sorry for the delay replying, been away all weekend. |
| 10-05-2008 | #6 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Realtek Vista_R205.zip/exe???? Hi Algypalgy, Realtek's driver downloads are bad about having a slow download rate or dropping when a new version first comes out. You might wait a a few days, or try during off peak hours late at night or real early in the morning. You may also try the ZIP version, and from the 3 different download sites available for each. Hope this helps, Shawn |
| 10-05-2008 | #7 |
| Vista Ultimate | Re: Realtek Vista_R205.zip/exe???? Grateful for the advise Brink, but already tried most of your suggestions, but I will keep at untill I am successful. Kind reards, Algypalgy. |
Similar Threads for: Realtek Vista_R205.zip/exe????
| Realtek help | Sound & Audio | |||
| Realtek Semiconductor Corp. - Network - Realtek RTL8139/810x Famil | Vista hardware & devices | |||
| Realtek 1.91 now available. | Vista installation & setup | |||
| Realtek 1.89 available now. | Vista installation & setup | |||
| Realtek AC 97 | Vista General | |||
