| windows vista home premium 32bit | sound uninstalled! So I just updated Vista on my machine, and after it finished updating, and restarting, my sound was gone. And every time I try to turn up the volume it says "No Audio Output Device Is Installed". But it was working before the update. D= HELP. PC: HP Pavilion dv 2000 (GA726EA#ABV) |
| vista home premium SP1 32bit | Re: sound uninstalled! go to the manufacturers website and download the drivers for that machine if you cant find them, go to device manager and click the sound device and then rollback/update driver or you could try restoring you system to an earlier time using system restore |
| windows vista home premium 32bit | Re: sound uninstalled! well actually i went to the device manager n i uninstalled my sound(conexant high definition) and then iam downloading it from a link hope it works! coz the rollback/update option wasnt available |
| vista home premium SP1 32bit | Re: sound uninstalled! ok, let me know the outcome.... nice one |
| windows vista home premium 32bit | Re: sound uninstalled! yeah iys solved thnx alot n sry for late reply |
| Uninstalled IE8 and Need IE7 for Sp2 64 Can It Be Done? | Network & Sharing | |||
| Accidentally uninstalled sound, how to reinstall? | Vista General | |||
| Uninstalled Sp1 RC2 now I have no sound | Sound & Audio | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| uninstalled | Vista General | |||
