Vista - Windows DVD Maker Problem
Old 10-22-2008   #1 (permalink)
Vista Home Premium 32bit
I made a slide show movie in Windows Movie Maker6(Vista) when I click on Publish To DVD it saves it and opens Windows DVD Maker. This where it goes strange:
The movie that comes up is an older movie that I had made earlier. I can't get kid of it in order to work with my new slide show movie. I have deleted the old movie file from my computer, however when I start over again the same OLD movie comes up again on DVD Maker.
Any suggestions would be appreciated.
Old 10-22-2008   #2 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Re: Windows DVD Maker Problem
Looks like you may have deleted the original, but the saved project is a copy saved on your pc. You should be able to find it by typing it's name into the start search box.
Hope that helps
SIW2
Problem with using Windows DVD Maker General Discussion
windows dvd maker problem Media Center
Windows DVD Maker Problem Vista music pictures video
Problem with Windows DVD Maker. Vista General
Problem with Windows DVD Maker Vista music pictures video
