Vista - Internet calls and VOIP Sound Problem
Old 10-25-2008   #1 (permalink)
Vista basic x64
I saw a couple of thread reporting the problem with a 'sound device error' in most VOIP installations. I tried to reply on them but they were closed so i've opened a new thread. I used 'freecall' and experienced the same problem but the problem is easily solved.
1. Uninstall the software
2. Right click the setup file and go to Properties
3. On the second tab - Compatibility, tick the - Run in Windows XP Compatibility mode
4. Run Installation again
The solution works for Freecall and will hopefully work for other software having the same problem.
Vikas
VoIP sound problem Vista performance & maintenance
VoIP phone sound problem Vista hardware & devices
sound device for just voip Vista hardware & devices
VoIP poor sound Vista music pictures video
Internet Safety Effort Calls on Phoenix to Get Net Safe Vista News
