| Vista Home Premium 64bit | Host OpenAL (ADI) Does anyone have any idea what this is? Just appeared in my installed programs, something to do with Creative, but i use onboard soundmax, which is good enough for me and don't have a soundblaster installed. Don't even know what installed it... vista 64prem |
| Vista Ultimate 64bit SP2/ | Re: Host OpenAL (ADI) |
| Vista Ultimate x64 | Re: Host OpenAL (ADI) OpenAL - OpenAL® and Windows Vista™ The software extensions were added to OpenAL just over a year ago, Quote: Changes and Bugfixes * Added new enumeration extension (ALC_ENUMERATE_ALL_EXT) to use AL on any soundcard / audio endpoint * "Generic Hardware" device only appears in the enumeration string if it can be used * Fixed alcGetIntegerv's requirement for an active context * Fixed alcCaptureOpenDevice so that it returns 'NULL' if the capture device fails to open * Fixed software reverb bugs (Reflection Delay and Air Absorption HF) It seems that it just took ADI (no idea if or when RealTek added it, but assume they have) a while to integrate it into their drivers (and can be installed manually from the link above). |
| Vista Home Premium 64bit | Re: Host OpenAL (ADI) Thanx Stormy13, i'll just leave it alone then... |
| Windows 7 RC x64 (7100) | Re: Host OpenAL (ADI) It's just the software needed for to use the OpenAL API, you may consider it analog to OpenGL but for Audio. Under Vista, is the only API that can actually use your Hardware Sound acceleration directly and EAX for Creative capable soundcards. Even Host based Creative cards (non-DSP cards like CA0106 Audigy SE and X-Fi Xtreme Audio) can use the API even if only for positional audio without EAX. |
| Re: Hiding the Host OS when startng MS VPC with host | Virtual PC | |||
| OpenAL + Kaspersky Anti-Virus = riskware | Software | |||
| Host to Host USB Connections | Vista hardware & devices | |||
| VirtualPC VM created in XP host hangs in Vista host | Virtual PC | |||
| Read-Host issue, won't store to variable when using multiple read-host lines | PowerShell | |||
