| Vista Home Premium 64bit | XP Sound Recorder codecs I have Vista 64-bit Home Premium. I managed to locate a copy of XP Sound Recorder, which I installed in C:\Windows\System32, & it seems to work fine. The sole reason I installed XP Sound Recorder was to quickly & easily reduce the file size of wavs, by converting them to MPEG Layer-3 32Kbit Mono 22,050Hz. (I have Audacity, which can certainly fulfill the same function – but it’s faster & easier through XP Sound Recorder.) HOWEVER… When converting file properties in my newly-installed XP Sound Recorder, it lacks the MPEG Layer 3 option in Format. Whoops! It’s a codec, & not part of the program. I then downloaded both the 32-bit & 64-bit Vista Codec Package – but still no luck. Does the Vista Codec Package even include an MPEG Layer 3 codec? (I thought it did.) If so, how do I associate it with XP Sound Recorder? Thanks in advance… Last edited by ululator; 11-01-2008 at 08:15 PM.. Reason: mistake |
| ?????? Sound Recorder ???????????? | Vista General | |||
| How to record sound clips or music using the sound recorder? | Vista music pictures video | |||
| sound recorder | Vista music pictures video | |||
| Sound Recorder | Vista General | |||
