| ultimate x64 | Hello, vistax64 Ultimate Does not sync with a microphone driver. I have Toshiba Satellite Pro U400-12p. I installed the Vista 64bit because I upgraded the ram to 4GB. Now, the driver of Conexant (which included in toshiba`s website) is not working. Downloaded everything just right, even tried the 32bit Version. None. It shows that it can upgrade, then "installing" the files, and at the end it shows "Failure" The cause of it, it shows I have no audio output/input installed. = speakrs are not working and the microphone ofcourse. Only when I remove the driver in the device manager and restart the machine, it gets fine. So, the Microphone does not work! How do I make it work? (at some tech store, they have tried the pc with vista home x32, and it worked.) I really need your help. Thank you. Nir. |
| Vista Home Premium 64bit | Re: Hello, vistax64 Ultimate Does not sync with a microphone driver. 64 bit OS needs 64 bit drivers... |
| Microsoft® Windows Vista™ Ultimate x64 SP2 Windows 7 7127 x64 | Re: Hello, vistax64 Ultimate Does not sync with a microphone driver. |
| HD Audio Driver for vistax64?? | Drivers | |||
Sun Java JRE version 6 update 10 on Vistax64 Ultimate | Software | |||
| ultimate: once again microphone is not working.... | Vista General | |||
| IXP SB400 AC'97 Driver vistax64 | Drivers | |||
| Blue Screen Error while installing VistaX64 Ultimate Edition | Vista installation & setup | |||
