Vista - Sounds wont play
Old 12-06-2008   #1 (permalink)
vista home premium
Sounds wont play
The volume on taskbar is turned all the way up like it playing but no sounds plays.
I dont know what happen to the sounds.I went to sounds and its say it's works.
Old 12-06-2008   #2 (permalink)
Vista Ultimatex64 Windows 7 build 7100
Re: Sounds wont play
Quote  Quote: Originally Posted by lynn618 View Post
Hey lynn,
Did the sound work before?
When you went to sounds and it was working do you mean here?
[IMG]file:///C:/Users/pooch/Desktop/Capture.JPG[/IMG]capture.jpg
If yes then try clicking configure and follow the Wizard to setup your speakers
Next click on properties
and then on levels
Then make sure that the sound is turned up
I hope this helps
Pooch
Old 12-07-2008   #3 (permalink)
Vista Ultimate x64_SP1
You most likely didn't set the output jack correctly.
Click on your output jack you are using in Realtek HD manager and go through the options that appear one by one. One of them will work.
I have mine set on "Front Out" in Vista and "Line Out" in XP.
PLEASE HELP!! DVD / CD Wont play Media Center
DVD wont play Vista General
DVD wont play in WMC Vista music pictures video
some sounds play even though volume is on mute Vista General
Re: How to play sounds from a batch file Vista General
