Vista - vista update crashing c media sound
Old 12-18-2008   #1 (permalink)
vista 32bit home premium
i have a c-media headset and i dont install updates because it has done this before.it is simple when the update ocures my headset has a staticky sound when playing any sound,the only fix is to re-install windows all over again(loseing everything).can anyone tell me what is going on?
my headset is an edimensional audio fx pro 5+1 usb headset+mic
note:mic seams permenantly on even if no sound is being done around it
always 1 bar
Old 12-18-2008   #2 (permalink)
Vista Ultimate x64
Re: vista update crashing c media sound
re330 Welcome to the forums.
This a C-Media update through Windows Update? If so it sounds like you have Automatic Update enabled and set to download and install any updates found. If so you might want to consider setting it to "download but don't install"; #4 here,
Windows Update - Windows Automatic Updating
and the next time the C-Media update shows up, opt to not install it and then hide it,
Windows Update
As far as having to re-install Vista to fix the problem have you tried all the usual,
1. Uninstall the update through Programs and Features (and clicking on the "View installed updates" link on the left, may be here or in the regular list of programs).
2. Rolling back the driver for the headset in Device Manager (locate the headset, double click on it, Driver tab, "Roll back driver").
Old 12-18-2008   #3 (permalink)
i have disabled auto updateing and it wont show up in instaled updates??
roll back dousent seamed enabled
btw my chip is the cm108
Old 12-19-2008   #4 (permalink)
Vista Ultimate x64
Not sure I understand this one. Are you asking if it will still show up as an offered update, or that it isn't showing as an installed update? If the first it will show up as an offered update until you either install it or set it as hidden. If the second have a look through all installed programs instead, if it is there it could be listed as from C-Media or it could be listed under the name of the headset manufacturer.
As far as the rollback option being grayed out it is only available if the driver has been updated at some point in time.
Now for the bad news regarding C-Media audio device users,
Quote:
Due to the expiration of Sensaura license, the driver download site will be temporarily suspended. We will reopen the download site when the new driver is available.
Drivers | C-Media Electronics
and has been that way since late September of this year. Means that you are stuck with whatever driver was available from the device manufacturer (Auzentech, BGears, HT Omega, etc) prior to that date, until such time as C-Media re-negotiates the Sensura license or finds an alternative.
P.S. What is the make and model number of your headset? CM108 is just the audio chip in it, not who the headset was made by.
Old 12-19-2008   #5 (permalink)
made by e dimensional as stated above
and the update shows as instaled in the update log but when i got do deinstall the update it dousent show up
Old 12-19-2008   #6 (permalink)
Vista Ultimate x64
Have you tried it with the drive available from eDimensional?
eDimensional 3D Glasses and Innovative PC Gaming Accessories
If it won't install open Device Manager and locate the headset, right click and select Uninstall and if it asks about uninstalling the driver, click yes. Reboot if required and if the Found New Hardware Wizard pops up cancel it and install the driver from eDimensional. If Vista tries to auto-install a driver for it (still haven't seen how you stop that from happening), let it finish and then install the driver over the top.
If that doesn't solve it uninstall through Device Manager again, and before rebooting (if necessary) unplug the headset, reboot and then try installing the driver without the headset installed. It should ask for you to plug the headset in, but may also fail if the headset isn't in first (won't know till you try).
Old 12-19-2008   #7 (permalink)
Inspirion 5101 Vista
I was having the same issue, even the speaker was gone by the clock, I removed the latest update, and had to put a check mark by the (display sound on toolbar again)
Glitterdog?
Old 12-19-2008   #8 (permalink)
what did you do to fix it????????????????
Windows Media Center Store Update Manager Constantly Crashing Vista General
Problem with crashing programs after Vista update Vista performance & maintenance
Vista Crashing while playing media Vista General
