Vista - Re-enable Conexant microphone?
Old 01-12-2009   #1 (permalink)
vista home premium 32 bit
I've disabled my conexant mic in "manage audio devices" while trying to get a plug-in mic to work. I expected to easily re-enable the mic, but instead, the system no longer recognizes it at all. Instead, it the message reads "No audio devices installed."
Is there a way to enable the resident mic without re-installing the OS?
Thank you...
Old 01-12-2009   #2 (permalink)
Vista Home Premium x64
Re: Re-enable Conexant microphone?
Quote  Quote: Originally Posted by czyp View Post
Thank you...
can you take a picture of your sound devices? usually no audio devices means that you have disabled it in device manager.
Old 05-21-2009   #3 (permalink)
Visa Home Premium
To re-enable the mic:
1. Right-click on Volume in Systems Tray
2. Select Recording Devices
3. Right-click anywhere in the window that pops up (Sound box).
4. Select "Show Disabled Devices."
The mic will then re-appear and you can enable it.
To enable Microphone in laptop Vista General
conexant high definition audio-microphone problems after updates Vista General
difference between 'Enable write cache ' & 'Enable advanced' Vista performance & maintenance
Conexant drivers Vista General
Conexant Soung Vista hardware & devices
