| Vista Home Premium 32bit | Vanishing sliders in Vista volume mixer Odd one this - googled it and didn't find much. I just noticed that when i open the volume mixer, it'll initially come up with some or all of the running apps using audio, but if i close it and then reopen again, one or more of them has vanished. This seems to be erratic rather than following any pattern. Any ideas? Like i said it's not something i've come across before. I reinstalled audio drivers, didn't help. 32bit Home Premium SP1 on Vaio VGN-N38E laptop. |
| Vista Home Premium x64 | Re: Vanishing sliders in Vista volume mixer Odd one this - googled it and didn't find much. I just noticed that when i open the volume mixer, it'll initially come up with some or all of the running apps using audio, but if i close it and then reopen again, one or more of them has vanished. This seems to be erratic rather than following any pattern. Any ideas? Like i said it's not something i've come across before. I reinstalled audio drivers, didn't help. 32bit Home Premium SP1 on Vaio VGN-N38E laptop. |
| Vista Home Premium 32bit | Re: Vanishing sliders in Vista volume mixer well i wouldnt worry, however i turned msn right down earlier, and now the slider has gone and i can't turn it back up again! |
| Vista Home Premium x64 | Re: Vanishing sliders in Vista volume mixer just to better explain, first pic is with MSN closed, as you can se, no slider for it, second picture is with MSN open but no slider because theres no sound from it, third picture is with the slider open on there because someone signed in, but if no one signs in, then you can create a sound wave, just go to the tools and select winks, this will bring up a slider called winks when you play a wink, close this and the winks window will switch to windows live |
| Vista Home Premium 32bit | Re: Vanishing sliders in Vista volume mixer Yep, opened mixer, opened an msn window and threw a nudge, and msn slider came up straight away! Knew it'd be a simple answer, cheers for that MrNeeds!! |
| | #6 (permalink) |
| Vista Home Premium x64 | Re: Vanishing sliders in Vista volume mixer |
| Volume Mixer? | Sound & Audio | |||
| Vista Ulti 64 volume mixer has been deleted | Drivers | |||
| Volume Mixer in Vista | Vista General | |||
| Red X on Volume Icon and Volume Mixer has disappeared | Vista General | |||
| How to save Vista volume mixer settings for IE7? | Vista General | |||
