Vista - sound in Vista
Old 02-16-2009   #1 (permalink)
vista x 64 home premium
sound in Vista
hi,
there seems to be a delay in me pressing play ,then about a minute later the sound will come out,i can turn my sound card off,and then it sometimes works,its like it freezes,is it because i got the sound card through fire wire,
Old 02-16-2009   #2 (permalink)
Vista Home Premium 64bit
Re: sound in Vista
Yes, probably
But why do you have the sound through firewire?
Old 02-17-2009   #3 (permalink)
Re: sound in Vista
hi,
its an external sound card,a cakewalk sp66 ,i got it as a better choice than the onboard one,
Old 02-20-2009   #4 (permalink)
Vista Ultimate 64
Re: sound in Vista
Quote  Quote: Originally Posted by steve1234 View Post
hi,
Is there a latency adj? I use a firewire audio interface with vista 64 works perfect.
You need to tweek it
Old 02-23-2009   #5 (permalink)
Re: sound in Vista
hi,
it doesnt do it all the time,just now and again,everything will not play sound,i find if i reset media options in explorer it works,and restarting the sound card,
by everything i mean windows media player
itunes
youtube
any sound that comes from the pc
then its like i reset and it comes on,
i know what you mean about the latency,
what music programs do you use with vista 64,
thanks
Old 02-23-2009   #6 (permalink)
Vista Ultimate 64
Re: sound in Vista
hi,
itunes
youtube
thanks
I use Cubase 4.5 and Sonar 7.02 Producer.
I see your using the SP66 By Cakewalk. Are you using Sonar as well?
Old 02-24-2009   #7 (permalink)
Re: sound in Vista
hi
i tried useing cubase sx but all the modi channels got mixed up,and the midi in keeps loosing connection,so i use vst and it seems ok,but want a more updated version of cubase,tried useing sonar but had problems with the midi,so went back to vst,
is 4.5 the new cubase out,
Old 02-24-2009   #8 (permalink)
Vista Ultimate 64
Re: sound in Vista
hi
Cubase 5 is the latest.
Good Luck, let me know if you need any thing !
Old 02-26-2009   #9 (permalink)
1 x Vista Ultimate x64; 2 x Vista Home Premium x64
Re: sound in Vista
Also make sure you have the latest drivers installed for the sound card. You may also want to go into your Bios and disable onboard sound if your MB has it. There could be some internal conflict over the sound devices fighting for IRQs (doubtful, but you never know).
Old 02-28-2009   #10 (permalink)
Re: sound in Vista
yeah thanks ll try that ,
distorted sound in vista/createiv x-fi titanium sound card Sound & Audio
Low sound from speakers and no windows sound on new vista Vista hardware & devices
Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND Vista hardware & devices
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Vista General
