| Vista Home Premium 64 | Razer Barracuda™ Vista will not instale I have vista64 prem I go to load the card with latest drivers. When istale startes it keeps asking me to instale the sound card - but it is all ready in . Is there any way t ofix this where vista see's my card in the pci slot . Now this is a new hard drive clean with vista64 only on it - my last hard drive had XP pro 32 on it this sound card worked great - same mb and every thing just new HD and os . |
| Vista Ultimate x64 | Re: Razer Barracuda™ Vista will not instale SHERIFFWoody welcome to the forums. Might want to take that up with Razer as they claim that they "fixed" that issue in the latest driver, Razer Barracuda AC-1 Driver v2.23 Quote: Razer Barracuda AC-1 Driver 2.23 Supported Operating System Version Supported Languages Windows Vista 32-bit Windows Vista 64-bit Driver v2.23 English Change Log: 1. Fixed issues on code 39 signing in Vista64. 2. Fixed issues in "Cannot load driver" in Vista32 and Vista64 Vista 64...Razer Barracuda AC-1 or X-Fi Fatality champion platinum - [H]ard|Forum you should be able to install the driver manually through Device Manager (select Update, and browse to the extracted driver folder that contains the INF), but you won't be able to use the Razer software to control the card. |
| Vista Home Premium 64 | Re: Razer Barracuda™ Vista will not instale yes i know this and i do have that driver downloaded . what I said was when i go to load that driver instaltion in the setup- it ask me to ples plug in razer barracuds ac-1 audio card device. as i all so said this car worked fine for me in my old hard drive with xp pro so i know the card works. what i need to know is y is it asking me this when in is in the pci slot i'v all was used for it . and i have took it out of the pci slot and rebooted then shut down and reput in the card this tells me the same thing |
| Razer Barracuda AC-1 issue. | Sound & Audio | |||
| seagate barracuda / vista compatability | Vista hardware & devices | |||
| Vista and Razer Tarantula USB Keyboard | Vista hardware & devices | |||
| Razer MS Habu at Windows Vista 64-bit | Vista hardware & devices | |||
| Razer Diamondback not working all the time in Vista Beta 2 | Vista hardware & devices | |||
