Vista - How to make Integrated and 3.5 jack Microphones distinct? (without using USB)
Old 02-27-2009   #1 (permalink)
Vista Ultimate x64
Hi. My laptop has an integrated microphone (SoundMAX Integrated Digital HD Audio).
I have an external microphone with a 3.5 jack. When I plug it in, Windows, instead of displaying two microphones, displays only the external one, but also recognizes it as SoundMAX Integrated Digital HD Audio.
Is there a way to separate these two microphones?
Note: When I use an USB adapter, Windows recognizes both mics. But I'm trying to know if it's possible to find a solution without using an adapter.
BTW, I'm using Vista Ultimate x64.
Headsets and microphones Virtual PC
Headphone Jack?? Sound & Audio
Compatible headset and wireless microphones for Vista 32 OS Vista hardware & devices
microphones Vista hardware & devices
Group-Object uses distinct formatter for grouped elements - any workaround? PowerShell
