| Vista Ultimate x64 | Crackling sound while working with graphics applications While listening to music in the background and working with graphics (CorelDRAW X4, Adobe Acrobat 3D), the sound crackles when scrolling or more complicated operations are performed. When the cracks are heard, Windows Task Manager shows visible peaks in CPU usage. The sound card is Creative Audigy 2 and the graphics card is ATI Radeon HD3650. The problem occurs only in Vista (32-bit, SP1) and not in XP on the same computer. UPDATE: I solved the problem by removing the graphics card and using the integrated graphics chip on the motherboard. Last edited by macic7; 03-01-2009 at 05:09 AM.. Reason: problem solved |
| sound crackling! | Sound & Audio | |||
| crackling surround sound | Sound & Audio | |||
| Bagof Wi (n.d) Crackling Sound | Graphic cards | |||
| Crackling sound | Sound & Audio | |||
| RE: Sound is crackling when listening to music. | Vista music pictures video | |||
