| Vista home premium 32 bit | Just upgraded to Vista Premium (help) This is my first post here so I do hope its in the right place, Yesterday I upgraded my other desktop to vista premium,all has gone ok except I cannot get the sound to work.I have used the troubleshoot etc assuming it might be a driver issue and have updated existing drivers.I keep getting the message this device is working correctly. I may be out of my depth here but went ahead with the install anyway. I have just seen that on the c drive the fold entitled "Old" is there and when I look the Realtek and items are here.is there anyway I can restore these to enable my sound to return. Sorry if its a bit non technical but its the only way I can put the problem |
| Vista Ultimate X64 SP2 | Re: Just upgraded to Vista Premium (help) First thing, i cant help you with reloading drivers If I dont know what system/model you have. List that and I will gve you the drivers to reinstall. Vista will install most, but there are a few you should re-install First thing you need to do is go to Windows updates and click "check for updates", download, and Install any updates to your system, and keep going back after restarts until It says "Windows is up to date- no updates are available for your computer" Then we will download and re-install the drivers (including sound) for your system. Last edited by rive0108; 03-01-2009 at 01:57 PM.. |
| Vista home premium 32 bit | Re: Just upgraded to Vista Premium (help) Thank you its a PB 500 Motherboard NEC GA 8TRC41OM NF Hope this helps and thanks again |
| Vista Ultimate X64 SP2 | Re: Just upgraded to Vista Premium (help) Thank you its a PB 500 Motherboard NEC GA 8TRC41OM NF Hope this helps and thanks again Support Intel Pentium D Dual Core Technology Intel® Pentium® Hyper-Threading Technology (HT Technology) with FMB Performance 2005 support Intel® Pentium® 4 processor in an LGA775 socket with an 800 MHz bus, 2.8Ghz to 3.8 GHz or higher Intel® Celeron® (D) processor in an LGA775 socket with a 533 MHz system bus, 2.8 GHz or higher Chipset ATI Radeon Xpress 200 Intel Edition Chipset with Integrated Graphics Processor System Memory DDR2 400 / DDR2533 / DDR2 667, 2 banks Support for up to 4 GB system memory Expansion Slots 1x PCI Express 16X 1x PCI Express 1X 2x PCI Ethernet Controller LAN 10/100 (Realtek RTL8100C) FireWire (IEEE 1394) Controller VIA VT6307 IEEE 1394 controller Audio Intel® High Definition Audio subsystem using the Realtek ALC880 audio codec IDE (HDD, ODD) 4 x SATA connectors 1 x Ultra ATA-133 connector |
| Vista home premium 32 bit | Re: Just upgraded to Vista Premium (help) Thank you its a PB 500 Motherboard NEC GA 8TRC41OM NF Hope this helps and thanks again Support Intel Pentium D Dual Core Technology Intel® Pentium® Hyper-Threading Technology (HT Technology) with FMB Performance 2005 support Intel® Pentium® 4 processor in an LGA775 socket with an 800 MHz bus, 2.8Ghz to 3.8 GHz or higher Intel® Celeron® (D) processor in an LGA775 socket with a 533 MHz system bus, 2.8 GHz or higher Chipset ATI Radeon Xpress 200 Intel Edition Chipset with Integrated Graphics Processor System Memory DDR2 400 / DDR2533 / DDR2 667, 2 banks Support for up to 4 GB system memory Expansion Slots 1x PCI Express 16X 1x PCI Express 1X 2x PCI Ethernet Controller LAN 10/100 (Realtek RTL8100C) FireWire (IEEE 1394) Controller VIA VT6307 IEEE 1394 controller Audio Intel® High Definition Audio subsystem using the Realtek ALC880 audio codec IDE (HDD, ODD) 4 x SATA connectors 1 x Ultra ATA-133 connector |
| | #6 (permalink) |
| Vista Ultimate X64 SP2 | Re: Just upgraded to Vista Premium (help) Before you install these Update Windows- then after re-installing these driver/software packages check device manager for yellow exclaimation marks for missing drivers, and we will go from there. Realtek ALC 880 HD audio codec/driver (sound driver & Audio Manager): Realtek Full software Suite ATI Radeon Xpress 200 (Graphics driver): ATI Catalystâ„¢ Display Driver |
| | #7 (permalink) |
| Vista home premium 32 bit | Re: Just upgraded to Vista Premium (help) Before you install these Update Windows- then after re-installing these driver/software packages check device manager for yellow exclaimation marks for missing drivers, and we will go from there. Realtek ALC 880 HD audio codec/driver (sound driver & Audio Manager): Realtek Full software Suite ATI Radeon Xpress 200 (Graphics driver): ATI Catalystâ„¢ Display Driver Last edited by Badpianoman; 03-01-2009 at 02:55 PM.. Reason: found more info |
| | #8 (permalink) |
| | #9 (permalink) |
| Vista home premium 32 bit | Re: Just upgraded to Vista Premium (help) Its showing it on Radion Express 200 Yes fully updated SP1 |
| | #10 (permalink) |
| Vista Ultimate X64 SP2 | Re: Just upgraded to Vista Premium (help) |
| Upgraded from Vista Home Premium to Ultimate. Both Versions on C D | Vista General | |||
| Upgraded vista to home Premium | Vista General | |||
| Upgraded hard drive and can not activate windows vista premium | Vista installation & setup | |||
| Upgraded to Vista Premium- Get Blue Screen | Vista installation & setup | |||
| Upgraded to Vista Home Premium - RE-install windows old files | Vista file management | |||
