Vista - Vista And SRS Audio Sandbox
Old 08-15-2009   #21 (permalink)
Vista Ultimate x64 SP2/ Windows 7 RC X64
Re: Vista And SRS Audio Sandbox
Quote  Quote: Originally Posted by rasso View Post
Quote  Quote: Originally Posted by DaKine73 View Post
rasso
unfortunately no answers from srs about the new sound driver for x64.
it will crash your sound, and you will still need to reboot to bring it back.
methinks ,,i solved my problem....i unistalled high definiton audio driver and then i installed srs v1.9 (64bit) ..then srs working perfectly for 2 days..i dont get a problem....i think srs problem solved ?
is your sound still working good? any sound crashes?
Old 08-21-2009   #22 (permalink)
Vista home basic 32 bit
SRS Sandbox
Thanks, this is good to know. I am using the trial version, now won't have to buy it... My sound stops and starts, stops and starts and I can not watch videos for more than a couple of seconds at a time...very frustrating, can not find answers to fix this problem..boo hoo..
Old 10-06-2009   #23 (permalink)
Vista Ultimate x64
Hi. Just thought I'd add my bit. What you have just said is pretty much it. I also am having the EXACT same problem. I have the same setup. I just purcased SRS SB couple weeks back. After a week of troubleshooting I filled a report with SRS Labs and received an email yesterday. Thay admitted that SRS SB is not compatable with x64 Vista and offered a refund. He also mentioned that a "Fix" should be about 2 weeks away around the time of Windows 7 release. I guess/HOPE that they have seriously timed this in order to work with Windows 7 as well as Vista x64. I sorta plan to replace Vista with Win7 anyway. Just a wait and see I guess. Good Luck to us all on this. It is a great plugin for sound. The best I have tried.
Rex
Old 10-06-2009   #24 (permalink)
Windows Vista Enterprise x64 SP2
Old 10-07-2009   #25 (permalink)
Quote  Quote: Originally Posted by rvrl View Post
Rex
Here is a tip for you now that srs have refunded your money.....dont do as i did!!!
make a back up of that email, or copy paste it somewhere secure. I had to reinstall my system, and i forgot to make a backuo of my important emails, im using ms outlook. so when it ws time to reactivate srs it aked me for the maunal activation code for some reason. i logged in to the website, i figured this info was to be there. Wrong!!!! the refunded my money and erased my loggon info to the srs website. so i was left out from activation.
I felt like my wife just kicked me out of the house! How can they do this? Simple they refunded your money, and you are no longer a costumer to them.
So keep those funky codes safe!!!!
Old 10-07-2009   #26 (permalink)
Vista Home Premium 64bit
I also have the Realtek HD 7.1 ACL888 in my MoBo.All I use is the Loudness Equalization though.Aimp2's EQ rocks my two desktop Logitech speakers I got at Office Max.They have what looks like a tweeter / midrange speaker and a subwoofer in each speaker.Are you guys talking about the SRS efffects for WMP ?
Old 10-07-2009   #27 (permalink)
to Blue 75
We are talking about the srs audio sandbox from srs labs. that srs effect you find in WMP is just part of a sound plugin. which makes your pc sound like a home theather on a bose system {well more or less}
SRS Audio sandbox issue Sound & Audio
Sandbox Application for 64-bit Vista? Vista General
What is that directory called sandbox? Vista General
Microsoft Launches Connected Services Sandbox Vista News
