DaKine73
For those who are using Vista x64 flavor with the SRS Audio Sandbox topping!
Many complains i have seen on the net about sound crashing when using this combo.
Hey dont fell bad!!!! I also have the same problem with SRS.
I came up with the why....? but not the how to fix it.
I have an MSI sli v2, with the HD realtek alc888, 7.1 capable audio connector.
I used to have installed windows xp x86, in this system and used SRS 32bit version and it worked great, never had a crash.
Now I re installed my system with the lattest trend that is ....Windows Vista Ultimate x64....i had to get myself the x64 version of SRS. I installed it and ran it, and now the problems start. It sounds great untill it crashes.
(I did install the 32 bit vesrsion of SRS in Vista Ultimate x86 for a friend and he doesn't suffer from crashes)
So my deduction here is that the problem lies in the x64 drivers of SRS or the capacity for vista x64 to handdle such a fine program.
(i have not tryed the x64 version of xp yet to single out if it is the xp/vista or is the 32/64 conflicts with SRS)
So if any one wants to join this discussion, to see if we can come up to the solution....i tell you there will be many happy ears out there!
I am one of the addicts to SRS the sound, its so rich! i can't just listen to the plain sound of the realtek eq.
- Alien Tech
- AMD Phenom 9850 Black Edition
- MSI K9N2 Platinum
- OCZ PC6400 SLI Edition 8GB
- Graphics Card(s)
- XFX Force 8600GT x2 (sli configuration)
- On board Realtek HD 7.1/ SRS Audio Sandbox 1.7 x64
- Acer H213H
- 1920x1080p 32bits
- SCSI\Disk____NVIDIA__STRIPE____74.53G Sea Gate
SCSI\Disk____NVIDIA__STRIPE___298.09G Hitachi
SCSI\Disk____NVIDIA__STRIPE___372.61G Hitachi
- PSU
- Power Up 550watts
- Case
- Alien Tech (new system in an old chassys)
- Cooling
- By Air 7 fans
- Microsoft USB Digital Media Pro Keyboard (IntelliType Pro)
- Logitech HID-compliant LX3 Optical Mouse
- 1mb
- Other Info
- This Rig is OC'd by 13% stock CPU is 2.5GHZ to 2.8GHz
FSB (HT)225MHZ
RAM is also OC'd Stock 800MHZ to 900MHZ
Ultra Media Dash SD/USB/eSATA/Audio/1394/CM/SM/CF-MD/MS
