| Vista Home Premiun 64bit | Microphone not working in Vista 64 with X-fi fatality soundcard I cannot get my microphone working. I have a PCI Express X-Fi Titanium Fatal1ty Pro Series audio card and Vista 64bit. I can hear audio with no problems but I cannot record or hear any input from my microphone which is attached directly to the back of the audio card. |
| Windows Xp Pro SP2 | Re: Microphone not working in Vista 64 with X-fi fatality soundcard ![]() Welcome to the forum spasters. First , check out the following pic and see if you are connecting the right jack at the right socket. In cases whereby the Microphone is not recording or not being detected by the soundcard, it is advisable to run the soundcard installation once again with the bundled cd and selecting repair to ensure that the installation is now complete and proper. Do also check that the soundcard has been selected as the default device for recording:
If the microphone volume is too low while recordings, check the Volume Controls to make sure the recording volume for the microphone has not been turned down. If changing the volume does not have enough of an effect on microphone volume, increase the (microphone) level: Close all back applications, especially, Sound Recorder or other multimedia applications.
Cheers dude |
| Vista Home Premiun 64bit | Re: Microphone not working in Vista 64 with X-fi fatality soundcard Thanks for the reply. I have checked where everything is plugged in and verified the mic is set up as the default in hardware manager sounds. Do you have any other suggestions? Tahnks |
| Help! Microphone on headset working on XP but not my Vista. | Sound & Audio | |||
| Microphone not working in Vista and Skype | Sound & Audio | |||
| Microphone not working with Vista Ultimate | Sound & Audio | |||
| cannot enable a correctly working soundcard | Vista music pictures video | |||
| EMU 0404 Professional Soundcard not working in RC1 | Vista hardware & devices | |||
