Vista - headset microphone stopped working...need help desperately!!
Old 03-22-2009   #1 (permalink)
Vista Home Premium 32bit
I bought a headset microphone to use with Skype about a week ago and it was working perfectly. Everytime I plugged it in it asked me something about choosing line in or microphone. I always chose microphone and it worked fine. Last time I used it, the same box popped up and I checked the "do not show this message again" box. Unfortunately after that, the microphone stopped working. The headset part (speakers) still work, but the microphone doesn't. I even exchanged it in the store for a new one and it still isn't working. PLEASE HELP. This is really really important to me!
Old 03-23-2009   #2 (permalink)
Windows 7 Ultimate 32Bit (Build 7600)
Re: headset microphone stopped working...need help desperately!!
Hi
Have you checked Control Panel>Sound>Recording and made sure that the mic is selected and is identified as 'working'?
Regards
UKMedia
Help! Microphone on headset working on XP but not my Vista. Sound & Audio
Headset Microphone stopped working Sound & Audio
Headset Microphone not working correctly Vista hardware & devices
Logitech Headset(Microphone) Isn't working Vista hardware & devices
bluetooth headset working good but microphone isn't Vista hardware & devices
