| Vista Home Premium 32bit. | Realtek Audio Problems Computer Model:a6200n Yesterday afternoon some guy was moving the wires behind my computer to make space to pass by and move out the couch... then my computer shut off I reconnected my computer and i know everything is correctly plugged in but my audio isn't working... i can't hear a thing. I am on Vista Home premium And I'm using Realtek High Definition Audio When i check the Sound settings everything is High and maxed out nothing is on mute and it shows that my speakers are emitting noise. I also did the driver update and it is 3/12/2009 6.0.1.5809 I think my computer isn't detecting my jacks or w.e. cause when i plug in my Microphone it doesn't work anymore. If anyone has any idea of why it is not working or how i can fix it please help. Some images that might help narrow down problems ![]() ![]() ![]() ![]() |
| Vista Home Premium 32bit. | Re: Realtek Audio Problems Oh yea and when i plug things in the little box doesn't come up anymore. (the one that says you have just plugged in something) |
| Vista Ultimate 64 | Re: Realtek Audio Problems Might try this: Realtek cards: No sound in Vista problem fix - FileCluster Reviews and also install the "KLite codec pack" Download K-Lite Mega Codec Pack |
| Vista Ultimatex64 Windows 7 build 7100 | Re: Realtek Audio Problems |
| Vista Home Premium 32bit. | Re: Realtek Audio Problems I installed K-Lite but the link above it asked me for a log in when i go to download but i see no registering page. My sound is still not working..... |
| | #6 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Realtek Audio Problems Hello TheWire, See if this may help: ![]() In the Connector Settings screenshot above, make sure that box is checked to see the pop-up when something is plugged in again. Test it with the Speakers device selected as the default playback device. Double check to make sure that the speaker is plugged into the correct jack on the back of the computer. Hope this helps for now, Shawn |
| | #7 (permalink) |
| Vista Home Premium 32bit. | Re: Realtek Audio Problems I just reinstalled my OS so now my computer is like new but the sound problem still continues.... I thought the System Restore would work but it did not do anything. Tells me my speakers are not plugged in when i checked a thousand times and plugged it in every jack avaliable and still no sound. |
| | #8 (permalink) |
| Vista Home Premium x64 | Re: Realtek Audio Problems I just reinstalled my OS so now my computer is like new but the sound problem still continues.... I thought the System Restore would work but it did not do anything. Tells me my speakers are not plugged in when i checked a thousand times and plugged it in every jack avaliable and still no sound. ![]() just get back to that screen and check the box there, when you plug in your speakers now, they should be detected and set them to "front speakers out" also, if you dont want to have jack detection on, you can double click whichever jack your speakers are plugged into, and set it from there. |
| | #9 (permalink) |
| Vista Home Premium 32bit. | Re: Realtek Audio Problems Yea i have the jack detection enabled and i done have the little green circle highlighted so i can click on it. |
| | #10 (permalink) |
| 32bit vista home premuim-SP2 | Re: Realtek Audio Problems |
| Realtek HD Audio & Xbox 360 Input problems | Vista hardware & devices | |||
| Sound problems with Realtek Audio | Vista hardware & devices | |||
| Realtek Vista Audio Problems | Vista hardware & devices | |||
| Realtek HD Audio Problems? | Vista hardware & devices | |||
| ASUS A8R 32-MVP/ Realtek ALC 882 Audio WDM & Codec Problems | Vista hardware & devices | |||
