Vista - Lost sound after installing webcam
Old 03-25-2009   #1 (permalink)
Vista Ultimate x64
Ok man its been a long time since i was on here. Anyway I bought a logitech webcam it had a built in mic and all that jazz, before I installed it I had a Sound Blaster XFi Xtreme Audio sound card in there, it worked fine no issues. When I hooked in and installed my logitech webcam my microphone no longer works on my headset I dunno if i disabled somethign or what I tried doing a system restore but to no avail if anyone is able to help with this that will be appreciated.
Old 03-25-2009   #2 (permalink)
Vista Ultimate x64
Re: Lost sound after installing webcam
Check the Vista audio properties on under Recording and make sure the mic for your headset is set as default.
Old 03-25-2009   #3 (permalink)
Vista Ultimate x64
i did heres a screenshot of it
Old 03-25-2009   #4 (permalink)
Vista Home Premium 64bit
What software are you trying to use this is?
If something like Skype, then you also have to select your audio source withing that software.
I've also noticed with Skype that you shouldn't set it to load at windows startup or some of the audio/video drivers aren't installed yet (boot sequence) and you can end up without sound or audio separately or together....
Also- what kind of computer/laptop?
- JC
Old 03-25-2009   #5 (permalink)
Vista Ultimate x64
I'm trying to get it to work period, it doesnt even pick up my microphone in sound recorder. Im using a computer as in the specs on my sig.
Old 03-25-2009   #6 (permalink)
The USB microphone is the webcam, right?
Have you tried removing the webcam and then trying your headset?
What kind of headset is it? It says plantronics, but is it USB, bluetooth, or 1/8th inch?
If it is USB and the webcam is also plugged in, try moving it to another USB port and away from the webcam. Also, are you running it through a USB hub?
This is a desktop, right?
Desktop USB ports can provide more power, whereas laptops are limited. Unpowered USB hubs are also limited in both power and bandwidth. (This is not a technology limitation, but high bandwidth devices normally use more power, so this is *mostly* the case)
- JC
Old 03-25-2009   #7 (permalink)
Vista Ultimate x64
its a 1/8th inch jack, I already tried removing all the web cam stuff and trying again but nothing,
Old 03-25-2009   #8 (permalink)
Silly question, but does your headset have a mute button? And be sure it is plugged in ALL the way. It doesn't take batteries, does it?
I've use a few plantronics items in the past, but don't know your particular model.
- JC
Old 03-25-2009   #9 (permalink)
Vista Ultimate x64
it does have a mute button but its not muted i already checked that, and doesnt take batteries.
webcam causes conflict with sound Sound & Audio
No Sound using Webcam - Vista & WLM Sound & Audio
Sound went away after webcam install? Sound & Audio
No sound from webcam Vista hardware & devices
stream.sys not found when installing webcam Vista General
