Vista - XP Sound Recorder: MPEG Layer-3
Old 03-25-2009   #1 (permalink)
Vista Home Premium 64bit
I need MPEG Layer-3!
I’ve installed my old XP Sound Recorder into my new (Vista) computer. It works… but lacks the MPEG Layer-3 Format I need for compressing WAVs.
In his earlier reply to me at
http://www.vistax64.com/sound-audio/189750-vista-vs-xp-sound-recorder.html ,
sanantonio007 says he can now access MPEG Layer-3 in XP Sound Recorder after following Brady Lee’s instructions here:
Help...This Missing CODEC thing is making me crazy
Lee’s instructions say that the “missing” codec problem is due to a Windows/System 32 file that should read l3codecp.acm instead of l3codeca.acm
Lee goes on to describe a
regedit modification to change the l3codeca.acm file to l3codecp.acm.
However, I already have a l3codec
p.acm file in Windows/System 32 (as well as the “erroneous” l3codeca.acm.)
So that doesn’t look like my solution.
Someone else told me that if I downloaded the MPEG Layer-3 codec from a dbpoweramp music converter link, it would install itself everywhere - & my XP Sound Recorder would be back up and running.
Has anyone tried that?
Does anyone know if (or where) I could get just the dbpoweramp
MPEG Layer-3 codec, & not lots of other stuff I don’t need or want?
Better yet… does anyone have a simpler solution?
All I want is to run my old XP Sound Recorder in Vista – WITH the MPEG Layer-3 Format WAV compression format, like it used to have!!!
Old 03-25-2009   #3 (permalink)
VISTA home prem 32bit SP2 --- XP Pro SP3 32bit
Re: XP Sound Recorder: MPEG Layer-3
Quote  Quote: Originally Posted by ululator View Post
Lee’s instructions say that the “missing” codec problem is due to a Windows/System 32 file that should read l3codecp.acm instead of l3codeca.acm.
Lee goes on to describe a regedit modification to change the l3codeca.acm file to l3codecp.acm.
However, I already have a l3codecp.acm file in Windows/System 32 (as well as the “erroneous” l3codeca.acm.)
Does anyone know if (or where) I could get just the dbpoweramp MPEG Layer-3 codec, & not lots of other stuff I don’t need or want?
Are you trying to record something that will create an MP3 file?
edit: record using the vista sound recorder then use a program from here
http://www.google.com/search?hl=en&q...t+.wav+to+.mp3
Old 03-25-2009   #4 (permalink)
ferrisits -
I downloaded the K-Lite Mega Codec Pack, & it did the trick. Now I can access the XP Sound Recorder formats & attributes I want.
Thanks!!!
Old 03-25-2009   #5 (permalink)
pacinitaly -
Thanks for the tip, but actually, I was just trying to make my old XP Sound Recorder work in Vista the way it used to in XP, for the sake of convenience.
I have Audacity for full-scale audio editing, but I wanted to use Windows XP Sound Recorder the way I used to, pre-Vista - for quickie conversions: compressing wav files for emailing, etc.
I appreciate your input!!
Old 03-25-2009   #6 (permalink)
pacinitaly -
thank you
I have been trying to find a file like I have on XP called messer
but nothing works. Whenever I try to record a stream, I also record sounds from the mic. If I disable or uninstall, the recording does not work.
stay well and good luck with that ( I'm going to try what you did)
Old 03-26-2009   #7 (permalink)
pacinitaly -
Do you have Audacity? I swear by it, & recommend it very highly. I use it for recording audio streams - plus a whole lot else.
Thankfully, it works as easily & as well in Vista (after a tiny bit of finagling!) as it had in XP.
Good luck!!
Old 03-26-2009   #8 (permalink)
pacinitaly -
Good luck!!
Thank you again very much
Sound Recorder Vista General
?????? Sound Recorder ???????????? Vista General
How to record sound clips or music using the sound recorder? Vista music pictures video
