Vista - My old pioneer A-Z360 amp has a DAT input.
Old 04-01-2009   #1 (permalink)
Vista Ultimate x64
My old pioneer A-Z360 amp has a DAT input, could I plug s/pdif coaxial into it?
Could I plug a s/pdif coaxial into the DAT input from my soundcards s/pdif coaxial out?
The amp has an optical in toslink also but the onboard sound from my motherboard only has a s/pdif coaxial out. It's a digital amplifier even tho it's an old amp. It's in great condition and sounds just as good as it looks for it's age.
I think it would do a better job than the onboard sound if i passed it through to the amp to deal with.
Thanks.
Old 04-15-2009   #2 (permalink)
Vista Ultimate x64
Re: My old pioneer A-Z360 amp has a DAT input.
Doesn't matter anymore i got a different motherboard in the end anyway.
Old 04-15-2009   #3 (permalink)
Vista business x64
one with digital optical SPDIF out?
cuz you couldave gotten a converter box to convert COAX to fiberoptic:
http://www.national-tech.com/prodima...-converter.jpg
Old 04-15-2009   #4 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by Ayporos View Post
Yeah i got a new board that has tos link optical out instead of just a coax digital out. My amp takes both but the board i was going to get just had coax out. My amps coax input is called a DAT input? It's an old amp & i was not sure if the DAT input would take coax from any source as DAT is some old digital tape format i think?
Old 04-15-2009   #5 (permalink)
Vista business x64
REEEEEE-EDITTTT (yarrr)!:
OK, recap:
DAT: digital audio tape
conclusion: useless.
optical in: CD optical in.
conclussiuon: useless.
Looks like you won't be able to hook your pc up digitally to it.. or atleast not unless you can get your audio card to emulate being a digital audio tape player or a cd player.. also it'd have to be stereo, no surround.
You're better off just hooking the amp up via analog.
Old 04-15-2009   #6 (permalink)
Vista Ultimate x64
OK, recap:
I can use the tos link optical in for stereo sound, I have plugged a soundcard into the optical in the past & it worked fine aswell as a dvd player for movies & a mini disc. As for the DAT input it has a slightly higher bitrate than CD even tho it's tape? apparently DAT tape is superior to CD & that's why they still use it in recording studios today.
The amps is actually 4 speaker surround sound? must be old.
I just wondered if the DAT input would work as the board I was originally after only had coax out with no tosh. Thanks for the responses by the way.
Pioneer DVR-K17 - Cannot set to DMA mode Drivers
Pioneer DVD-RW (DVR-111) in Vista Drivers
Problem with Pioneer Dvd burner Drivers
Chinese Traditional Input using Phonetic Input Vista General
pioneer inno Vista General
