Vista - Convert WMA to MP3
Old 04-03-2009   #1 (permalink)
Vista Ultimate x64 SP1
Convert WMA to MP3
Bought a new 120GB Zune!!! < YAAAAAY! >
It doesn't play the .wma files I bought from my music service < BOOOOOO! >
My Service says "Burn the 200+ DVD's worth to CD in whatever format you want, then Rip everything back" < BOOOOOOOO! >
Google came up with an app named "DB Power Amp" that's both 64 bit capable and is supposed to be able to convert the whole batch directly to a (MP3) file.
Does anyone have any experience with this app? Or are able to recommend something else/better?
Old 04-04-2009   #2 (permalink)
Vista Ultimate x64 sp2, Solaris x64
Re: Convert WMA to MP3
Hello Scotteg,
There is free and simple application to convert the wma to mp3 files. You can
download Free WMA to MP3 Converter - Freeware convert WMA to MP3. and give it a try. It's called Free WMA
To MP3 Converter.
Cheers...
Old 04-04-2009   #3 (permalink)
Vista Home Premium x64
or you could use this, just uploaded this so it may still be processing.
You messed up try again
convert xls to pdf PowerShell
Vb6 Convert .NET General
convert vhs to Dvd Chillout Room
RE: Convert VHD to ISO? Virtual PC
Convert EML to DBX? Vista mail
