Vista - Mic only records left audio
Old 04-17-2009   #1 (permalink)
Vista Home Premium 32bit
I recently (today) bought a Philips SBCMD650/00 microphone, plugged into my soundcard (pink rear 3.5 mm plug) and was trying it out, only it seems that my mic only records the left, if i use the playback function it only uses the left side, if i look in SAM Broadcaster, it only uses it's left side, the right side does have some sound, but it's only some background noise, no real sound. (produces background noise even if it's turned off) I want to take it back to the shop i bought it and trade it in for a new one (have 2 weeks time to do that) but i wonder if it is able to make sure my microphone records monotone, and not stereo. I'm only going to use it for Radio presentations so if someone knows an solution in SAM broadcaster to make it monotone, it will work to.
Mic only records on left side Sound & Audio
No MX or A records for .... Vista mail
First 400 Records in SQL Statement VB Script
How to add new records to EventLog? PowerShell
Audio no longer has left and right balance Vista General
